dougrainer
May 05, 2023Nomad
Since the Trailer appears to have the standard LP tank mount ring, that means you have a 20 lb LP cylinder. Average weight of an empty 20 lb cylinder is 17 lbs. add 20 pounds LP and your combined weight is 37 lbs. LP weighs about 4 lbs per gallon. Your tank holds 5 gallons. NEVER TRANSPORT A DOT RV LP CYLINDER IN A CAR/TRUNK/PASSENGER AREA. Doug
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
