neu
May 06, 2023Explorer
Reisender wrote:
Hi Neu. I am not a fan of packing heavy objects at the rear of the trailer to offset hitch weight. Instead just consider getting them over or slightly behind the axle. Packing heavy items at the very rear of the trailer can introduce a pendulum effect which can cause a sway situation.
Check your manual to see if Audi has a maximum height on how much the ball can be above the mount. I know some manufacturers do including tesla.
Even swapping out the lead acid 12 volt for a lithium battery can help the situation.
Is your Audi a Plug in hybrid or full electric?
Happy camping Neu.
Thank you for the tip! And if I place a heavy object in the back of the trailer to reduce the tongue weight to an acceptable level, is that a good idea or still a bad one?
I have a gasoline engine, not a hybrid, 2.0T with 252 hp and 370Nm of torque in stock.
Thanks for the tip on the lithium battery. My battery is actually on its last legs, so I have more than one reason to consider replacing it with a lithium one.
I don't have the user manual at hand, but I have a photo of the sticker on the hitch itself. It seems that the maximum height is 6 1/4. However, I'm not sure what they meant by 1/2. The diagram is confusing to me. Could you help clarify?
UPD: Aaah, now I understand. The maximum lifting height here is 1/2 inch. What am I supposed to do now? Can I drive with the trailer lowered down?
As far as I understand, with a single-axle trailer, I can tow it with the tongue tilted forward. I just need to remember about the tongue weight and the clearance.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
