JBarca
May 07, 2023Nomad II
Boomerweps wrote:neu wrote:Reisender wrote:
Hi Neu. I am not a fan of packing heavy objects at the rear of the trailer to offset hitch weight. Instead just consider getting them over or slightly behind the axle. Packing heavy items at the very rear of the trailer can introduce a pendulum effect which can cause a sway situation.
Check your manual to see if Audi has a maximum height on how much the ball can be above the mount. I know some manufacturers do including tesla.
Even swapping out the lead acid 12 volt for a lithium battery can help the situation.
Is your Audi a Plug in hybrid or full electric?
Happy camping Neu.
Thank you for the tip! And if I place a heavy object in the back of the trailer to reduce the tongue weight to an acceptable level, is that a good idea or still a bad one?
I have a gasoline engine, not a hybrid, 2.0T with 252 hp and 370Nm of torque in stock.
Thanks for the tip on the lithium battery. My battery is actually on its last legs, so I have more than one reason to consider replacing it with a lithium one.
I don't have the user manual at hand, but I have a photo of the sticker on the hitch itself. It seems that the maximum height is 6 1/4. However, I'm not sure what they meant by 1/2. The diagram is confusing to me. Could you help clarify?
UPD: Aaah, now I understand. The maximum lifting height here is 1/2 inch. What am I supposed to do now? Can I drive with the trailer lowered down?
As far as I understand, with a single-axle trailer, I can tow it with the tongue tilted forward. I just need to remember about the tongue weight and the clearance.
Whoever approved that hitch sticker needs fired. WDH only limits!
And that diagram of where the ball should be is nuts. Most hitch rise measurements are listed by its base, so 1/2” in this case. Only time I’ve seen the top of the ball used for measuring is in a WDH set up manual. And unless you buy an oddball (pun intended) tow ball with an extended base, no regular tow ball is 5 & 3/4” tall, most are 3-4” tops.
First off, I totally agree; this sticker has issues; it clearly states the "hitch" is only rated for carrying 441# in weight-distributing mode. This needs further clarification by the manufacturer. It may be the car frame cannot handle a weight-carrying setup. We do not know the weakest link in this car setup.
Now to the dimension specs listed, this car receiver hitch is custom-made for this vehicle by the manufactures specs to work both with the car frame and the physical receiver hitch. If you look closely, there are 2 specs shown.
1. The bottom of the tow ball mounting surface is to be no more than 1/2" above the top of the inside of the 2" square receiver tube.
2. The center of the tow ball is to be no more than 6 1/4" behind the centerline of the 5/8" ball mount locking pin.
Both specs refer to the leverage a 441" tongue weight rating can create in torsion within the receiver and car frame system. In technical terms, they limit the amount of moment arm the trailer hitch ball mount or trailer hitch WE shank and head length is used for max. weight rating.
Those dimension ratings can be worse than weight distribution or weight-carrying ratings in Neu's quest to level out his camper. He is trying to use a high-rise drawbar and needs an even higher one to level out the camper. Both can be over the ratings of that receiver, or car frame, with or without a WD hitch on a 441# trailer loaded tongue weight.
Neu, I suggest getting it in writing from Audi what those numbers mean for your VIN number vehicle for both the weight disturbing and weight carrying ability along with the max. tow ball rise height and length from the receiver pin hole can be. And please report back any findings. I have seen receiver ratings before on total ball rise, just not as spelled out as yours are.
Hope this helps
John
EDIT: 5/7/23 Corrected spec # 2 above to reflect the rear overhang of the tow ball.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
