path1's avatar
path1
How do I Calibrate a volt meter?
I have couple cheap volt meters. They don't give show the same numbers. Any ideas how to calibrate?
I'm not sure of a cheap and good way. Maybe something that plugs into 120 and then inverts to a known 12 volt number?
Thanks
(Elec is not one of my better known quality's)
  • You don't calibrate a volt meter, you don't likely have the equipment to do it. Only a cal lab or the manufacturer can do it, the equpment is
    very expensive.
  • GordonThree wrote:
    You'll need a known quantity calibrated voltage source, like 2.048 volts. The calibration part is easy, just write the delta on the meter someplace obvious.
    Problem is finding the voltage source
    is the difference linear across the scale?
    bumpy
  • A new carbon-zinc battery is 1.56 volts. Not an alkaline battery...
  • You'll need a known quantity calibrated voltage source, like 2.048 volts. The calibration part is easy, just write the delta on the meter someplace obvious.
  • The only answer I can see where that's possible is to compare it to a known good one. Then you'd have to buy or borrow a good one. They are inexpensive.
Having RV issues? Connect with others who have been in your shoes.24,311 PostsLatest Activity: Sep 05, 2025
