lc0338
Nov 21, 2015Explorer
MEXICOWANDERER wrote:
GOOP
Dirt cheap
Press nozzle flat against crack and smear a trace right down the crack nozzle wide
When puncturing the nozzle seal for first use, use a PAPERCLIP to control flow.
Continue one half inch past the end of the crack.
The repair is stronger than the parent plastic
I have repaired dozens and dozens of badly cracked 5 gal plastic water bottles this way and 3 years later customers claim no failures. Even for the two where a chunk of plastic had to be bonded. Wuuwee!
I suppose you are referring to goop GLUE as opposed to goop HAND CLEANER :)
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
