TURNKEY wrote:
I can get the fridge to be much colder but then it will freeze whatever I have in it.
Once again my question is how to get the freezer to be colder but NOT the fridge.
Wish i could trick my fridge into getting cold enough to freeze items. Then back it off a bit. What are you doing to make it that cold.
I would go back to those settings. Then install slim pieces of foam between some of the cooling fins in the fridge. That should result in colder freezer temps and the ability to keep adding foam strips until you reduce the effectiveness of the fridge fins enough to keep food from freezing.
