TURNKEY wrote:
Thanks for the replies. I already have temperature controlled fans in the chimney and a battery operated fan in the fridge and freezer. I can get the fridge to be much colder but then it will freeze whatever I have in it.
Once again my question is how to get the freezer to be colder but NOT the fridge. I believe the solution will entail more insulation around the freezer compartment and possibly inside the freezer....just wanting your thoughts or suggestions.
The freezer will get 0 to 10 degrees F regardless of the refer tstat setting. If you are getting temps above 10 degrees F and the refer is at 33 to 35, then as I stated, you have a problem with either the Thermal Mastic or the upper cooling unit is not sealed to the box correctly. What Freezer temp do you want? Doug
