mrad's avatar
mrad
Explorer II
Aug 05, 2014
How do I get rid of odor in water
The last couple of times out we have noticed an odor when using our hot water. I am wondering if some of the antifreeze made it's way into the hot water heater, and after not draining it for a couple week period could be causing the odor?
Should I try to get some bleach in the hot water heater to kill the odor?
  • I would suggest shutting off your hot water tank heater and cooling it. Then use the isolation valves to isolate it. Remove the drain plug, and then stand out of the way, and lift the safety valve. Water should shoot out of the tank.
    Now what you need is a thinner hose that will fit into the tank through the drain plug opening, and spray water around in there from outside as it comes out through around your spray hose. This is attempting to get the pink from the tank.
    After that, fill the tank up partially, and drive around a bit to slosh the tank, then drain plug again and let it all out.
    After that, either one, or the other, or both, you might get to the point where you don't notice it.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
