BBdawg's avatar
BBdawg
How do I Hang a 2 1/2" blind(s) on the styrofoam walls?
We are going to replace our day/nite shades which are mounted inside a valance with faux wood 2 1/2" blinds. We are going to remove the valence because the new blinds are too wide/deep to fit inside the valence.
Once the valence is removed, the only place to mount the new hanging brackets is on the wall outside and above the window. At that location, there is only the 1/8 inch panel board and then 2 inches of Styrofoam then the outside fiberglass wall.
The normal mounting is to use two screws into the "wood" header board, which is not used in an (our)RV.
AS these faux wood blinds are very heavy, I would prefer they remain on the wall and not on the floor following our future travel.
What is the best way to fasten them to our Styrofoam walls?
  • RoyB's avatar
    RoyB
    Explorer II
    You will probably have to mount a wood trim piece across the whole top of the window and mount the blinds to the board.
    Roy Ken
  • 2 and a half sounds too big maybe 2 inches would fit or 1 inch
