j-d
Jul 13, 2014Explorer II
I'm wondering if part of why a muffin fan IN the fridge is that by keeping the air moving, it keeps that fin thermistor from being satisfied a little longer?
Your fridge isn't in a Slide, right? Those must have a fan on the outside coils.
What's your Fridge Make and Model? If it's a Norcold, they shut the cooling off every so many (36?) hours as a poor man's defrost. It isn't active defrost like a home unit, just stops cooling an hour or so.
Is it Frosting on the Fins? If not, and in the Dry West, might not be frosting, and it's a Norcold, turn it OFF for 10-seconds or so every day. That'll keep the cooling unit running full time.
If it IS Frosting, needs to be cleared of that frost. I'm doing that now with a pump sprayer with water. Seems to be the fastest way. but the door's still open those few minutes.
Speaking of door, do you have good contact at the gaskets? ALL the way around? On our Norcold, we have to physically push the corner opposite the latch, every time we shut the fridge or freezer door.
Finally, check installation of your fridge. There should be NO dead space above or to either side. And, nearly no space behind. The idea is for the heat of the outside coils to create a draft that passes only through those coils. Some of us here have put baffles behind the coils (between coils and inside of coach wall) to direct draft through the coils. This is specified in installation directions.
I have two little (80mm square frame, 25mm thick) computer fans blowing upward from the bottom of the coils. If you buy those, the very cheapest have sleeve bearings and won't last as long as ball-bearing ones. I still get a couple seasons out of the cheap ones. Walmart has a four-pack of fans for $7.
