MEXICOWANDERER
Sep 21, 2014Explorer
Forest Camp.
Lbs of fuel per kWh is the industry standard for determining efficiency. If you maintain temperature so as to force the A/C to operate 100% of the test it is a valid test. Also, do the same test, same duration 0% generator loading. This will give you some perspective in case you are curious.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
