ktmrfs
Sep 22, 2014Explorer III
here's another SWAG. 13,000BTU AC. Let's assume draw is about 12A and PF=1, so 12Ax120V = about 1500W load. 1500W=5000BTU (IIR 1W=3.3BTU). Let's assume the generator inverter is near 100% efficient (which they are close to, at least for this excercise) OK, most internal combustions engines run about 20% thermal efficiency. so to get 5,000BTU/hr output= 25,000BTU/hr input. Propane is about 80KBTU/gallon, so figure 1/3 gallon of propane/hr.
Note: do NOT use the AC output BTU, and it doesn't violate any physics that AC output BTU is greater than the input BTU. An AC MOVES heat from inside to outside it doesn't create heat, except for the energy needed to overcome the losses in the heat transfer (compressing the gas and letting it then boil to remove heat)
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
