woodgeezer
Aug 01, 2014Explorer
Repair can get difficult. Do you have the same paper in a closet, or cupboard wall that you can "borrow" enough to do the patching? Match the pattern with the patch and place them together. Cut both pieces at the same time, and you have a good match. I always make the patch irregular in shape to hide the outline.(Like doing a wood veneer repair). A simpler and more eclectic solution is to add a decorative molding or patterned cover over the damaged area. Higher contrast and covering all window sides, makes a "custom look".
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
