- BurbManExplorer III
Dryheat36 wrote:
We use one screw for the slot and Velcro tabs at the bottom. Has never fallen off or rotated out of position.
Ditto, works well, and is easy to remove to change the battery. - vermilyeExplorer IIA 3M Command Hook for the slot in the back of the clock, and a small "blob" of Fun Tac on the bottom to keep it from rocking while moving. Can't permanently mount it since the battery compartment & setting controls are on the back.
- Dennis12ExplorerDrill 2- 2" holes through the clock and the wall. Get some 3/4 in chain put it through the clock and wall and weld it. Problem solved. Or you can look at your wrist.
- DevocamperExplorer
MitchF150 wrote:
I take it off the wall and put it on the bed when traveling. When camped, it goes back on the wall... :)
Good luck!
Mitch
x2 - Dick_BExplorerScrew-in wall anchors. I drilled two holes in the frame of the clock and use long screws thru the frame and into the anchors.
- obgrahamExplorer
dalenoel wrote:
x3toedtoes wrote:
Mine is hung just by a screw in the slot. It has never fallen off.
x2 And has worked in TT and the MH. Both times it was in the center of the unit and not near the back end where bouncing is more pronounced.
Never needed the Velcro. - ReneeGExplorerWe used heavy duty self adhesive Velcro. Works. Also use it for other applications too.
- Larry-DExplorer IIHeavy duty Velcro to hang our large (8x10”) atomic clock with weather info. Two years no problems.
- Triker33ExplorerMine has one screw for the slot and Velcro tabs at the bottom. Has never fallen off for over 18 years of Full Time use.
- ScottGNomadOur last TT, a Wildcat, used a screw and a piece of Velcro as others have deescribed.
Our new AF hangs from one screw and flops all over the place when moving.
(Another project)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
