ScottG
Mar 02, 2015Nomad
landyacht318 wrote:
Thanks for quick response. So I imagine the LM 2596 supplying a steady 5 volts would also operate the gauges properly?
I have one of those on a computer fan whose hub gets too hot at Absorption voltages and it holds a rock steady voltage no matter the input voltage, and has been plugged in for 6 months now, continuously.
Any theories as to why my cleaning of this stock unit caused the range to change and raise my gauges?
I don't know what the Dodge CVR output is exactly but if it's like the old Ford part then it needs to be about 6 Volts. If you use a 5V regulator then everything reads way too low (I've tried it!).
Don't know why cleaning it changed things - weird.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
