landyacht318
Mar 02, 2015Explorer
Well, I opened up the cluster, removed the limiter, and there, in the same place as the photo in the OP, is a little adjustment knob.
I could have easily moved this during cleaning. I don't have an analog voltmeter so I cannot adjust it properly, and I do not know what it was actually set at before. Also with its age, perhaps it is foolish to put this back into use after adjusting it.
It strikes me that I have the opportunity to dial in my Fuel gauge so half a tank actually indicates half a tank, instead of indicating 5/8ths a tank. This unit appears to fit this bill nicely. I could mount it remotely to easily adjust the set screw.
DROK 3a buck converter
While the temp gauges and OP gauges will have a 'new' normal range, I have a mechanical OP gauge plumbed in, and merely tolerate the Stock gauge. The Oil light is still operational as well.
I decided to practice soldering with my newish 100/140 watt weller gun. The primitive circuit board has a bunch of pins with a mechanical connection. They all now have a nice base of solder meeting the traces.
Same with the voltage limiter attachment points.
Here's to rock steady gauges in my future.
There is a capacitor on the CB traces between (+) and (-)
.47M250 V U
The V is actually a triangle.
.47M250 V U
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
