- Old-BiscuitExplorer III
2oldman wrote:
Old-Biscuit wrote:
How would you know that?
Over time the air pocket can be absorbed into water........then you will need to re-establish the air pocket
Rest of quote.....
"or pressure will increase due to expansion of water when heated (typically PRV will weep when this occurs)."
That and 30 yrs. of operating boilers.......all kinds/types/sizes
Simple 'Thermal Dynamics' - 2oldmanExplorer II
Over time the air pocket can be absorbed into water........then you will need to re-establish the air pocket - Old-Biscuit;
Good explanation! - Old-BiscuitExplorer III
2oldman wrote:
enblethen wrote:
How do you control that?
The water heater needs an air space near the top. Water should not be over the pressure relief valve port.
Normal filling of water heater will establish the air pocket by design of tank and position of dip tubes.
See previous picture.......
Over time the air pocket can be absorbed into water........then you will need to re-establish the air pocket or pressure will increase due to expansion of water when heated (typically PRV will weep when this occurs).
To re-establish air pocket
Turn off water supply
Open hot side of faucet to relieve line pressure
Hold open PRV via lever until water stops running out
Let PRV snap close
Turn on water supply
Close faucet - 2oldmanExplorer II
The water heater needs an air space near the top. Water should not be over the pressure relief valve port. - The water heater needs an air space near the top. Water should not be over the pressure relief valve port.
2oldman wrote:
enblethen wrote:
I don't know what that means.
You do not want the water heater tank "full".
Air Pocket - 2oldmanExplorer II
You do not want the water heater tank "full". - Old-BiscuitExplorer IIIBasic RV water system
- bacabunchExplorerThanks guys!
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
