Dutch_12078
Aug 05, 2018Explorer III
Colonel Monk wrote:Dutch_12078 wrote:Ralph Cramden wrote:Colonel Monk wrote:
Glad to know those SeeLevel II gauges really do work. I was eyeballing them for my new rig and was wondering if they were worth the money. Sounds like they are.
CM
The only issue Ive found with Seelevel is to make sure the wire carrying the sender data to the panel is not tied too, tied along with, or touching/crossing an 120 VAC wire or routed next to the AC side of the converter. That can cause interference and result in a bad signal. It needs a couple of inches clearance.
I haven't had any signal problems using the original "screw through the tank" wiring, but if I was installing the wiring from scratch, I think I would use shielded wire just be safe.
Yeah, shielded signal wire sounds safe. They probably ought to include it since it's difficult to know where the AC wiring is in your RV.
One of the selling points is that you can reuse the existing wiring in most cases. Plus there is so much variation in RV layouts that probably any length wire they provided would be too short in some cases, and way too much in others. I've done two installations on my own RV's and four more on other people's rigs, all using the existing wiring with no noticeable signal issues.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
