Clay_Smith
Sep 16, 2016Explorer
While on the subject of grease caps, I have one more tip.
We have all seen how the grease always pushes past the seal at the spindle. This is only natural as the internal pressure increases with temperature or altitude. On all of my vehicles (except boat trailers) the first time I remove the grease cap, I place it on a hard service with the open end up and with a center punch I nock a pin hole into the center of it. The hole is so tiny that you should only see it when you hold it up to the sun.
Being the hole is so tiny, dirt and water don't pass, only air. So now as the internal pressure would otherwise increase, the air can now escape without pushing the grease past the seal.
In over 30 years of doing this, I have never experienced any ill effect or anymore grease leaking past the seals. I hope that many of you will appreciate this idea.
Just don't do this on a boat trailer, that is where you want to use the "Bearing-Buddy" to keep from sucking in water as you back the hot hubs into the cold water.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jun 10, 2023
