MEXICOWANDERER
Sep 17, 2016Explorer
If from the inside a good splotch of grease seals the hole then Clay Smith's trick will work fine. The days of Hectorite clay based greases* is long gone. What these greases did was wick oil from a remote clot of grease and keep a bearing well lubricated. Meaning the area between the inner and outer bearings could be packed with grease and last a long, long, time. That doesn't work any more so putting extra grease in the hub cavity is a waste of money.
*Example: Shell Oil's Darina AX.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jun 10, 2023
