westend
Sep 18, 2016Explorer
ernie1 wrote:Packing the area between the two bearings will do a couple of things: It prevents less rust to form in the hub. It will allow grease to melt/flow that is not inside the bearing.
Mex,
Today I just put in new wheel bearings for my rv and always wondered whether one should pack grease in the hub area between the inner and outer bearings and also how much. I asked around and got a variety of answers but none really definitive. So, today I packed the heck out of the hubs and am hoping for the best. Are you saying it's not necessary, not a good idea or it doesn't make any difference with the new greases?
As the bearings warm up grease flows within the bearing. It also heats that adjacent grease that you packed into the hub middle. That heated grease just outside the bearing now can flow to the bearing surfaces.
If you absolutely filled the entire hub, you may see that your dustcaps are moving. I'd pull them now and then to remove the grease inside.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jun 10, 2023
