- MEXICOWANDERERExplorer77 ways to change a light-bulb
- SaltiDawgExplorer
Old-Biscuit wrote:
Channel locks to remove
Rubber mallet to install
Yup! I believe that's the reason god invented those two tools. - RVhikerExplorerI put a medium sized slot screwdriver where the lip of the cap meets the axle and tap gently; the cap separates a bit and then the screwdriver can pry off the cap. I use a gently applied rubber mallet to tap the cap back on. My caps don't dent, and they last forever. Of course, dented they last forever, too.
- 2oldmanExplorer IIIn the video the one he took off doesn't look at all like the new one.
- BarneySNomadMoved to Tech Issues forum from DIY.
- rhagfoExplorer III
RVcircus wrote:
K Charles wrote:
Take it off with channel locks and then reuse it. Why would you smash a good cap.
It doesn't smash it when I tap it. I only replaced mine because there were bearing buddies on there. That's also why I asked how other do it...2 replies and 2 different responses.
You were beating it with a Ballpen hammer! :S You can use channel locks or tap off with a rubber mallet! - jfkmkExplorer
RVcircus wrote:
Chuck_thehammer wrote:
100 ways and none are wrong... some just do more damage than others.
No one would do it the way I do... but I have been doing it this way for 50 years.
I specialized in brake repair .. and I might do 5 cars/trucks a day. so lots of grease/bearing caps..
and the tool I used is home made... I make a new one every 10 years or so.
and I do NOT do U-tube.. or most other social media.. so I did not view your clips.
I figured I'd get a different answer from everyone and we all think our ways right. I know mine isn't the best, but it's what I do and it works. Hammer & wood block...sometimes I dent them and sometimes I don't.
I don't think I would have used your method, but they're only dust caps....doesn't matter if they're dented or not. - beemerphile1ExplorerBuy yourself a dead blow hammer or even a rubber mallet instead of that ball peen.
- TerryallanExplorer IIMy covers / caps are rubber. I just pull them off
- naturistNomad IIhttp://www.ebay.com/sch/items/?_nkw=SnapOn+GCP10+Grease+Dust+Cap+Bearing+Puller+Plier+Tool&_sacat=&_ex_kw=&_mPrRngCbx=1&_udlo=&_udhi=&_sop=12&_fpos=&_fspt=1&_sadis=&LH_CAds=&rmvSB=true
https://www.etrailer.com/search/grease+cap+removal+tool
Take your pick. Ones I'm most familiar with have the pliers with a built-in rubber mallet.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
