lenr's avatar
lenr
Explorer III
Sep 02, 2018
How long do RV ACs last?
I've been through 3 Dometic air conditioners in 5 years. My son's Coleman is freezing ice on the evaporator coil--sure sign of low Freon. It's 3 years old and the freeze sensor is in place. We both run our ACs all summer long set to a high temperature to control moisture and keep cans from exploding in the heat. I did have a Dometic that lasted from 2005 to 2013, also run in the summer. Is Coleman now getting crappy Chinese evaporators like Dometic? So, how long should an RV AC last?
  • lot has to do with your incoming power. if they are running on low volts its tuff on them ,could burn a new out in a heart beat.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    one coleman is 14 years old, the other coleman is 9 years old. No problems
  • Had one that was replaced after about a month, another is still going after 10 plus years.
  • Probably depends on how much it gets used and whether it's maintained. In the NW the temps are such that I don't use the AC very often - my 92 works just fine.
  • I have two Dometic low profile a/c's on our '97 Dynasty that are 21 years old and still going strong. I did have to replace a fan motor on one of them about 10 years ago.
  • The Dometic in our 1999 Layton was still going strong when I sold it this summer. But, we only used it on occasion, no constantly.
    Does it get sufficient voltage/current to prevent damage? I don't have any experience with the Coleman products, but I think the unit on our new Outdoors RV is a Coleman, so will have to look.
  • My Dometic briskair is 16. I would say it's had average use, not like being in Las Vegas in July.
