- westendExplorer
campncouple wrote:
The above posted on 8/23/15
We have just brought home 2002 Damon Intruder. - ol_Bombero-JCExplorer
valhalla360 wrote:
Still not clear what type of generator we are talking about.
Make/Model/Rated wattage and what you are trying to run would be helpful.
As others have said, there should be no problem running it pretty much continously.
As above - more info would help..:@
~ - wa8yxmExplorer IIIUsually 1/2 to 1 hour for exercise 1st of every month.
WHEN NEEDED.. (For example when on the road in hot weather) as long as needed.
When powering a Ham Radio Field day.. 25 hours
When powering house during a power fail.. As long as needed or 3 days (IF gas tank is full) whichever comes first.. After 3 days I need to re fill tank.
Onan generators are designed for the long haul.. They can easily handle runs lasting several days or even weeks. I knwo many folks who run 'em 12 hours a day every day from like May through September (They sell Soft Serve ice cream from a truck) First ONAN I ever worked on was so employed. - MEXICOWANDERERExplorer11-days after hurracan Daniel for the Kubota 6 cyl. The Yamahahahahaha Kubota 3 cyl. ran for three months except for oil changes. 24/7, 90+ days.
- BobboExplorer IIIWhen exercising, 2 hours.
When using, as long as needed. Days if necessary. - Mandalay_ParrExplorerI've run mine for 3days straight. No problem.
- valhalla360NavigatorStill not clear what type of generator we are talking about.
As others have said, there should be no problem running it pretty much continously. - CampncoupleExplorerThank you all. The cover is not original to the unit. It was replaced at rv center with a cover from a propane unit and ours is a gas unit. Is there any difference? Do you think this could be the problem? They told us it was not original but replaced because other cover was missing. It cools fine but will turn off after awhile .
You all are so helpful. Cannot get to our Service Center until Oct. 1. The cover was put on at the RV
Garage where we bought unit. Due to being used...no warranty. - Is this an RV designed Genset or an aftermarket stand alone Genset? RV Gensets should NEVER shut down due to heat if all of its parameters are to spec and it is installed to spec in the RV. Some are water cooled (Diesel) and some are Air cooled(usually Gasoline). Doug
- DrewEExplorer III
joebedford wrote:
Don't take the cover off - at least if it's an Onan. They rely on the cover to duct cooling air.
I assumed Mex was referring to the outside panel/door that is typically installed (as part of the motorhome chassis), rather than the access hatch on the generator unit proper. In some cases opening that panel and aiming a fan in might make a noticeable enough difference.
It wouldn't hurt to check the engine cooling fan, air louvers, radiator (if water cooled), etc. for leaves, mouse nests, and general debris and clean out any that you find.
(As for how long I run my generator for, it depends mainly on what reason I am running it for. It runs longer when I want to use the roof air conditioner than when I want to heat up something in the microwave or top up tires with an air compressor.)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
