Campncouple's avatar
Campncouple
How long do you allow your Generator to run?
How long do you usually run your generator? We have been having such hot weather that we turn it on while mornings are cooler but we notice that after several hours it will shut down.DH feels it gets too hot.
Have any of you experienced this problem?
Thank you for your time.
  • My Onan 4000 has a warning label that states over heat damage can occur if the unit is operated with the service panel removed.
  • Don't take the cover off - at least if it's an Onan. They rely on the cover to duct cooling air.
  • Our 7.5kw diesel Onan in the front of our MH has run just fine for over 12 at a time in 100* + temps.
    Bill
  • They are air cooled and shouldn't shut down. Make sure oil level is OK. Don't know which generator you have. Some of the Onan gas generators have fuel pump over heating problems. My fuel pump was changed out under warranty. The generator will also shut down if your gas tank gets low so you won't run out of fuel. Does it throw an error code?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
