_DJ_1's avatar
_DJ_1
Explorer II
Jan 29, 2017
How long should a charge last?
I got my trailer in July '16. I put new Trojan 6 volt batts in it. It sat down at the Dealer from Oct to early Jan in frigid temps and solar covered with snow while they fixed a bunch of stuff and remodeled some others. I went down to check on it around Christmas and make sure the solar panel was clear.
Too late!! Batts were stone cold dead. And more than likely frozen. Talked to the service manager and said not to worry, he would replace the batts before I picked it up.
When I picked it up the volt meter only said 12.0 volts. SM told me they don't come charged. I got it home and plugged it in. Looked at the batts and I honestly can't tell if they are new or not.
A few days later I checked and the volt meter was flashing 13.5 and FULL. I unplugged shore power and shut off the solar and checked it each day. It fell a little more than .02 to .03 per day running nothing more than the gas sniffer. After 7 days the volt meter read 11.7.
The weather has been cold, 10 t0 20 degrees, but I'd thought the batts would last longer than 7 days. I am suspicious I have been lied to. Like thawed out the old batts and put a charge in them?
Thanks for your help......DJ
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
