Mike134
Jun 07, 2021Explorer
2oldman wrote:Mike134 wrote:If any of my a/c are blowing 75° air for more than a couple minutes, they're not functioning properly.
this guy has your answer, I'd take the same measurements on your home's A/C to see if it's cooling correctly.
You misunderstood you want a 20 degree temperature drop across the cooling coil. If your house is at 95 to start you want 75 discharge, start at 75 want a 55 degree discharge. Hopes this helps.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
