restlesswind's avatar
restlesswind
How Low is Too Low (Voltage)
Sometimes when we hook up to 30 amps,the AC volt drops to less than
110volts when we run the microwave.
(I have a voltmeter plugged in near the MW)
My question is,how low is too low before I have to worry about damage to equipment
  • otrfun wrote:
    Old-Biscuit wrote:
    108V is my minimum even though my surge protector doesn't shut power down until 104V
    I'm sure you're referring to an EMS (electrical management system).
    Just to enlighten folks that may not know, surge protectors do not provide any protection against continuous low or high voltage. Surge protectors only provide protection against momentary high voltage surge or spikes from lightening strikes or other momentary electrical anomalies.
    Some surge protectors DO protect from low & high voltage conditions.
  • Also check voltage at post. If OK there when microwave on it is your plug or connections in the RV C/B panel
    Art.
  • 108V is my minimum even though my surge protector doesn't shut power down until 104V
  • RoyB's avatar
    RoyB
    Explorer II
    I really start getting nervous when it hits 110VAC... Especially with the high wattage items...
    Roy ken
  • Ivylog's avatar
    Ivylog
    Explorer III
    My management system in my MH shuts the power off at anything less than 108V. In my Airstream I've been running the micro at 100V off a Honda 2000 and other than taking longer it seems to work fine.
  • 10% is about it. So from 120v that would be dropping down to 108v.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
