72cougarxr7
Nov 04, 2017Explorer
MrWizard wrote:72cougarxr7 wrote:MrWizard wrote:
Over 900 hours on this one, the last one 2000+
Approx 3000
Wow, what was needed for maintenance and repairs other than oil changes?
i replaced the 30amp RV outlet
and i replaced the battery and the starter solenoid,and one pull rope
it broke when i pulled on it, when the starter would not turn over (worn out vibrating in place) (you should check them for wear, replace or repair)(cut off 6" and tie a new knot in the pull handle)
the rest was just oil and spark plug air filter,
3100 is a great generator
How often did you do valve adjustments?
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
