Thanks for the replys and to 'set the stage' for the issue here, he went to the rig for something and when he closed the door the step would not retract all the way back in. Then he heard a clicking from near the steps, apparently from not enough voltage to retract them all the way. I went over and told him we need to check the batteries. The coach batteries, 2 6 volters, 1 was way low on water in all 3 cells the other was way low as well. We topped them off with distilled water then plugged it in to shore power. I checked the terminals with a multimeter and had only about 6.5 volts between the two. I thought there would have been at least 12 volts. Another issue here? Perhaps the batts. are toast?
