ewarnerusa's avatar
Jul 01, 2016
How much battery charging from alternator?
Having spent a few years here I often read about the concept that while a typical trailer wiring connection from the vehicle to the camper will supply 12V, it is of low amperage and as such the camper batteries are just being trickle charged. The reasoning being very long wire length of inadequate diameter between the alternator and trailer wiring harness. However, this wiring can be upgraded which results in better charging capacity.
I've recently begun reading a solar panel forum and sticking to the RV section. I've noticed that every time a discussion comes up, one of the frequent posters immediately chimes in to first install a battery isolator to allow for alternator charging and that the alternator will provide more power in an hour than solar panels can in days. No mention of wiring upgrades, just this battery isolator concept. This poster clearly knows his solar but I don't get the impression of actual RV knowledge beyond carry over solar concepts.
I recognize that alternators are rated to deliver a healthy supply of amps, but this concept from the solar panel forum doesn't mesh well with what seems to be the common thought here on rv.net. So can anyone enlighten me on how many amps one can expect for battery charging from an OEM trailer wiring arrangement and from an upgraded wiring arrangement, and what this battery isolator may do? Thank you.
