ewarnerusa
Jul 01, 2016Nomad
pianotuna wrote:
It is simple. I have dual charging paths with #8 wire. If my house batteries are hungry I do see up to 70 amps--but only for a brief period of time. As the starter battery reaches fully charged the amps taper. If I turn the fridge on 120 volt and power it with the inverter from the house jars, then I see between 25 and 30 amps of charging--but that is a short fall on what the fridge is drawing.
Would the battery isolator separate your starter battery from the circuit once full and allow the alternator to continue to deliver higher amps to the hungry house battery bank?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
