profdant139's avatar
profdant139
Explorer II
Oct 31, 2023
How much capacity is lost if converter isn't Li-friendly?
(This question was prompted by a different thread, but I thought it may warrant a separate thread.)
If I get Lithium batteries but my converter is old school, how much capacity (amp/hours) will I lose? I know the old converter will not fully charge Lithium batteries.
For what it is worth, I often connect a 120 watt solar panel to my batteries and often can boondock for a week without any other charging device. That charge does not go through my converter -- I just use alligator clamps from my solar panel to my battery.
Thanks in advance for your collective wisdom.
(And yes, I know I should update my old converter, but I don't want to do that unless I have to.)
  • Horsedoc wrote:
    I don't have a dog in this discussion, but Lithium scares me with all the fires that have taken place. (Geezers get worried over nothing.) I think I will stay with the lead/acid and genset.
    LiFePO4 is not a chemistry that is susceptible to thermal runaway and fires. While it is possible you pretty much have to shove an iron spike right through its shorting out all the internal layers and even then, it is mostly a smoke show. don't confuse Nicad and nickel metal hydride with LifePo4
  • My SIL went to a Yamaha ATV mechanics course and they were big on showing early Lithium battery fires. The tech were told to walk away if a battery fire started and just protect the surrounding area.
    He thought I was crazy installing LiFePO4 batteries under my TT bed.
    If you do a little online research, you will find that LiFePO4 batteries are safer than all other batteries.
    You can go online and watch Will Prose and others take a drill to them.
    I’ve seen two battery fires in vehicles, one actually blew up. Standard Lead Acid.
  • Even after all these years folks still giving advice on lithium fires when not even talking about LiFePO4 chemistry being used in rv's. LOL
    I believe I said I didn't want one. Go buy yourself a whole pile. Did you see any advice I gave? Nah, don't think you did.
    Have a good day
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
