time2roll
Mar 30, 2015Nomad
I find it odd the charging took 3x as long as at home. More likely the battery was lower on charge than you think. Did you monitor the charge to verify it was not shutting down intermittently? Need an ammeter to verify the charger is working same on inverter vs. utility power. Most don't charge to 100% while camped because the last 10% does take an extended period.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
