Gdetrailer
Apr 03, 2015Explorer III
pnichols wrote:Gdetrailer wrote:
You have a built in "regulator" (older alternators used a separate regulator which was often mounted near the battery), many newer alternators also communicate with the vehicles BCM (Body Control Module) and the BCM will control the alternator rotor current and has charging curves that it will follow.
Thanks for your long explanation on how altenators work. I already was aware of most of what you said as I used to be an EE before retirement.
However I'm not sure that I laid out any "misinformation" in my long post explaining what happens in my case - including what is implied and stated in Ford's published performance specifications for their V10 engine 130 amp alternator. Our motorhome came with twin coach batteries and I doubt that Winnebago would expect them to burnout/destroy/blow fuse links/whatever on the chassis alternator system under any conditions that these batteries might be in - including them being completely flat. Our Ford motorhome has a computer controlled 5-speed (6 speeds internally) TorqShift transmission, so most likely the altenator also has what you call a BCM to go along with the other computers on board. It's indeed keeping the alternator from over-heating under heavy current loads - probably as you say via control of rotor current - hence protecting it during recharge of low RV batteries ... as I would expect to be happening. By the way, our motorhome's engine has a huge radiator fan that of course does two things - it sucks air through the radiator to cool it and pushes air back onto the alternator to cool it. Just as a side point, our motorhome can continue to travel with a blown alternator .... just run the built-in generator when going down the road and tape the boost control "ON" so that the generator is supplying all engine current by means of the coach and starting battery being all connected together in direct parallel ... as Winnebago designed it.
Regarding flat vehicle batteries - I have throughout my life had some "flat" vehicle starting batteries and after jump starting the engine - let the engine idle for hours to bring the flat battery back up. This is even including 1950/1960's era engines with their vintage generators and alternators in cold Michigan winters. I'm of the opinion that modern alternators are capable of more than we think.
The marine community expects a lot out of their boat engine alternators all the time and I don't think that all of their marine engine alternators are necessarily the special marine versions with sophisticated battery charging circuits built in.
I doubt that ambulance packages include better technology alternators .... just maybe a bigger one, or maybe two instead of one, of the same type that came stock on my E450 chassis.
You incorrect.
Ambulance prep has CONSIDERABLY higher amperage alternators over the standard non prep package..
2014 Ford AMBULANCE PREP PACKAGE
Per, link above for F350/450/550..
Ambulance (47A/47L) and Fire/Rescue (47J)
Prep Packages
47A
47L
47J
Dual heavy duty alternators, 157-amp plus 200-amp (67A)
In other words, 357 AMPS worth of alternators!
F350 vans get a 225 Amp alternator which is MORE than a non prep package will get.
Additionally the package INCLUDES.. EPA Special Emergency Vehicle Emissions which IS DESIGNED for long extended idling.
Along with Elevated Idle Control (SEIC) has been integrated into the control module
and is standard.
Depending on vehicle the package often includes dual batteries..
Basically in a nut shell, Emergency vehicles are typically bought with the Ambulance/Emergency Prep Package.. Fire companies typically do not buy a vehicle directly off the dealer lot.. They can't if they want to be able to get warranty work done. Using a non ambulance prep vehicle for ambulance or emergency use WILL VOID the warranty.
By the way, using the vehicles alternator for a "one off" recharge of a dead battery isn't going to kill the alternator..
However REPEATED CONTINUAL usage in that mode WILL SEVERELY SHORTEN THE LIFE OF THE ALTERNATOR.. Along with many other components under your hood..
I have rebuilt a few alternators over the years, mostly due to extreme high mileage usage so I am familiar with what can go wrong with them.. One of the more interesting failures was one that started to charge at a lower current than it should..
When I opened it up, I found three of the six diodes had broken solder joints.. The high mileage with normal under the hood heat from heavy hauling had created enough expansion and contraction of the diode leads that it broke the solder joints. Resoldered the diodes and put back together and it charged like it was new again..
The point is, extended idling creates a lot of underhood heat, the engine compartment really relies on the vehicle MOVING for the MAJORITY of the time the engine is running. The radiator fan is designed to ASSIST during low speed, stop and go traffic and heavy long hill pulling. At idle that fan is LOAFING.. Just because it is spinning doesn't mean it will keep the under hood temps in check under extended idling.
HEAT is your enemy, it will destroy electronics very quickly..
You are more than welcome to do what you want to do..
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
