Fleet_Man
May 23, 2016Explorer
My Sunnybrook trailer had the Dexter E Z Lube wheel ends. I would see old grease pushing out after several pumps and kept pumping until fresh grease appeared. When I did not see grease pushing out as expected, I stopped pumping and pulled the wheel. As expected and as others have indicated, the inner grease seal failed and grease was being pumped into brake shoe area. Easy cleanup if caught early. After that, I replaced the failed inner seal and resorted to the old tried and true method of hand packing the bearings. A Lisle bearing packer works too if you don't relish hand packing those rather small roller bearings.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
