Likes_to_tow
May 26, 2016Nomad
BB_TX wrote:Likes to tow wrote:
Are you guys kidding me???? Is this post real???? For those who used several tubes to grease your bearings on an EZ Lube system I know where your grease went!!
Pull the brake drums and look at your brake shoes. EZ Lube axles were primarily designed for boat trailers that get submerged in water. The RV industry picked up on this "easy care-free" idea as a marketing tool. You guys are in serious trouble when you need your brakes!!!!!
You know nothing about where my grease went. I comes out the front of the hub just like it is supposed to do, just as shown in Dexter videos. Have used the EZ Lube system 3 times since new (8 yrs)and brakes still work like new, and no grease on them.
Another one who simply does not know how the system works.
Yes I know how the system works but keep in mind when the grease seals wear out or you do not jack up the trailer and spin the wheel as you shoot grease in as per the instructions from EZ lube you will be soaking the brake shoes!! Many folks on this and other forums do not like EZ lube hubs because of the tendency to have trouble.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
