fj12ryder
May 27, 2016Explorer III
Huntindog wrote:Okay, that's not the most ridiculous thing I've ever read, but it's pretty darned close.
The first big problem here is that there are only two kinds of grease seals. Those that leak, and those that will leak.
That's right. There has never been a grease seal made that won't fail at some point.
The next problem here is that WHEN a grease seal in the easy lube system fails..... It is unseen. It is most always discovered after the damage is done.
So for those of you that are giving good reports on using this system... I am happy for you now.
But at some point your seals WILL fail too. It could be next week, next year or the year after. For all you know, they may have failed now.:E
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
