westend
May 27, 2016Explorer
The biggest issue I see with these hubs is that what is going on inside the hub is unseen. There is no reliable way to see if bearings are getting enough/too much grease or if the grease is leaking into the drum area, except by removing the hub.
If an owner has to remove the hub, repacking, using a bearing packer, is not that difficult. If an owner used that Almagard grease that Mex suggests, repacking bearings would be in a large service interval (probably every five years?).
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
