mkirsch
May 27, 2016Nomad II
fj12ryder wrote:
You're basing your opinion of the EZ Lube hubs on a used trailer that does appear to have been severely overgreased. My experience with my hubs is the polar opposite of yours, but then I know how mine have been treated from day one, you only know what the guy has told you about yours. If I had the same experience as you I may feel the same as you.
If the EZ Lub hubs worked as designed, it is not possible for them to be "overgreased."
You're supposed to pump until clean grease comes out, right? Pump more in, same amount's supposed to come out, right? Shouldn't make a bit of difference whether it's dirty old grease or clean new grease, so... How can you "overgrease?"
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
