JimK-NY
May 01, 2021Explorer II
valhalla360 wrote:
If you look at the label, each device will give the acceptable voltage range.
But I wouldn't be too worried as that's not unusually high for a charger.
That does not seem to be the case. My LED bulbs and NovaKool refrigerator are rated to at least 15 volts, but I could not find specs for other devices including: furnace, water heater, Flojet pump, toilet pump.
No, the 14 plus volts is not high for charging but that does not mean that devices are OK with that voltage. Many older LED bulbs would not handle it.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
