JimK-NY
Mar 14, 2022Explorer II
The situation is even worse than described. Your laptop runs on dc battery power so you are losing efficiency by inverting to A/C current and then the laptop needs to convert that to dc of the correct voltage. Both processes lose efficiency.
A better solution is to use a "car" charger without the need to invert the current. With a bit of checking you should find this for your laptop. I do the same for other charging when possible. That includes items such as charging camera batteries.
Actually I am surprised that an inverter is over 80% efficient. Even small ones put out a lot of heat and have built in cooling fans.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
