There is 830w flat on the roof of our MH and I doubt we could do what the OP wants to do in winter due to so much overcast, but anyway---
You need the Latitude to calculate the optimum tilt up for the panels facing South, assuming no twirling. You need insolation tables for that location during those months to get an idea of how much sunshine vs overcast is likely. (Can get that on-line)
Pick a number for AH used in a day. Say 100, but could be more with the furnace on. Pick a number for time with sunshine on a sunny day there, say 5 hours. You need to average 20 amps, which would be about 600w worth of solar (300 would do 20 at high noon briefly then it is less the rest of the time, so pick a number--I pick 600--YMMV)
Now you still have all those overcast days in winter, so have a generator too. Absolute must! And a decent sized charger that can do 14.4 or so volts for the Bulk stage.
You have them coming and going from the RV, so if it is sunny while not there, solar can catch up a bit compared with the higher AH use when they are there. Luck of the draw if that does any good. Might.
All very chancy, and I don't think we could do that. Winter is not a good time for solar!
