I appreciate the mostly constructive answers. Others shouldnt even post. We dry camp at the most 7 days at the moment, however that might change. We do not use the lights much the main draw in the summer is the water pump for dishes and showers. We do not use the bath houses.. In the spring and fall the heater blower would come on. Those are the main draws. From what I gather the more the merrier and certainly if it was just a weekend I would consider less.
I believe that i will be increasing the battery bank, undecided if Ill add two more T-125's or sell them and get a pair of L16's upfront. Space and adding hitch weight are something to think about. I will start with around 500 watts or so with two panels, leaving space for more to add of we need it. We want to downsize our generator as the Honda 3000 is 135lbs and humping that up and out is getting to be a bit much. I want to sell it and get a pair of 2000's. One would be plenty to run on cloudy shady days to bump the batts up. A 2000 only weighs just under 50 lbs.
Once I find a good sale and install I will post for others to learn fro as well. While there were alot of posts. I wanted to hear from real time issues.
Happy Trails!!
