Ideally the batteries should not be drawn down more than 50% before being recharged. With 240 Ah that means a draw down of 120 Ah and for that 100 Watts or solar panel is all that is needed. I have that and the two 100 Watt panels recharge the batteries in only a few hours and the rest of the day are not doing anything. The rule of thumb of 1 Watt solar for every 1 Ah or battery to charge was on right on the money for us.
A heater fan is not an energy hog by any means. The fridge and lights are what tend to draw the most current. Upgrade the tungsten lamps to LED's and you can reduce their energy consumption by 90%.
By all means install a Trimetric or other digital charge meter so you will know exactly how much your systems draw in a 24 hour period.
If you add more than 200 Watts of panel output you should add more battery capacity to your bank as well or the extra output will not provide any additional benefit.
