ctilsie242
Feb 14, 2017Explorer II
Lots of good info here. I am still in the process of looking for a class "C", so depending on the rig I get, I either will have two AGM batteries at minimum, or if there is more room, my ideal is three sets of two 6 volt AGM golf cart batteries, which will have plenty of power for a fridge and spinning a furnace fan.
I definitely will be using more than one MPPT charge controller. At the minimum, one for the roof, and one for the set of portable panels.
As for a furnace replacement, the ideal would be a Truma unit, but because they don't retrofit those, I may look at a vented Platinum Cat in addition to a Cheap Heat system. This way, when boondocking, heating is covered via electrical, propane, and gasoline (via the generator.)
As for wattage, I know for my use, 100 watts won't even replenish what the propane fridge consumes from its control board. 250 watts is -minimum-, but ideally, I want an order of magnitude more, which allows me to have enough power, so tossing the propane fridge is feasible.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
