bka0721
Feb 02, 2015Explorer II
midnightsadie wrote:
I have a MB diesel to, in the garage , no need to start it, diesels can sit for years and fire right up, do put a trickle charger on the battery if you can.and the house battery to.
One should be careful in leaving their diesel trucks for years. Seals, gaskets and other things dry out, as well as the Diesel fuel degrades as does oil. To state a diesel truck could be started without being freshened up is not something I would ever follow.
First, fuel degrades and there is debate on whether to keep a fuel tank filled or not, to stop condensation. Diesel will form organic material that will clog filters.
It would be best to maintain a habit of starting and driving the vehicle once a month, to exercise the shocks and tires, as well as the suspension. Keeping D-Con and other material in the engine compartment will help keep the pest from chewing down your wire insulation and reflective material around your turbos and engine parts.
Keeping your batteries charged with ensure longevity and in areas different than yours, Freezing temperatures, it will keep them from freezing.
b
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
