BarabooBob
Apr 26, 2019Explorer III
If the chassis has grease fittings, they should be lubed at every oil change. Use a high quality grease and put in just enough to get the rubber boots to plump up just a little bit. Do NOT put in so much grease that you can see it come out around the boots. The boots are suppose to be a pressure system that pushes the grease back into the joint.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
