anon125's avatar
anon125
how often should the chassis be lubed?
ours was lubed (we hope) in 2014. did a 3500 mile trip to socal and back, had the engine serviced then parked it in a barn till now.
thanks all
  • Ours is a 2010 Itasca Suncruiser. According to the manual the chassis lube is due at every oil change. Also the PowerGear levelers require lubing at the same interval.
  • You should get it done now if it’s been stored for 5 years. I would think under normal use once a year should be fine.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
