Ivylog
Aug 12, 2017Explorer III
My DW says I own too many trailers...more than 10. In the last 10 years I can only remember doing one...maybe because it was last month and only on one side of a boat trailer. I do remove the caps and it t grease has hardened I fill the cap with 90 weight gear oil and put it back on quickly. If the trailer is to heavy to wiggle the tire I will jack it up so I can check the bearing adjustments.
On the subject of tires...I only buy used LT takeoffs (5-7 tread left and less than 3 years old) for my smaller trailers.
PS: I've only been doing these things for only 40+ years so time will tell if it works.:B
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
